purview-app-category
application
Configures the application category type for this custom (user-defined) purview-application definition
This parameter is applicable only for the 802.11ax APs. Define the purview-app-category type of this custom application definition. Apply this custom application definition in the purview-application-group and purview-application-policy contexts.
Supported on the following platforms:
  • Access Points — AP310i/e, AP410i/e, AP460i/e, AP505i, AP510i/e, AP560i/h
    This parameter is not applicable on the legacy APs (AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8432, AP8533). Use the app-category parameter instead.
Syntax
purview-app-category <PURVIEW-APP-CATEGORY-NAME>
Parameters
purview-app-category <PURVIEW-APP-CATEGORY-NAME> Select the category best suited for this application definition. The ExtremeAnalytics for ExtremeCloud IQ - Site Engine, formerly known as Purview™, supports 36 application categories with 2457 applications.
Note: Refer to Examples below for the app-categories supported by the Purview™ engine.
The default setting is custom. Use this option to categorize your internal custom applications, so that they do not appear as unknown traffic.
nx9500-6C8809(config-application-Custom)#purview-app-category
ads              biz              certs            cloud
cloudcpu         corp             custom           db
education        finance          games            health
location         mail             news             other
p2p              proto            realtimecomms    restrictcontent
search           shopping         social           sports
storage          streaming        travel           unknown
updates          vpn              webapp           webcontent
webfile          webmeet
The following example displays the canned (built-in, system-provided apps) starting with 'h':
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#application h [TAB]
hashforcash  hashunited   hoopla
The following example, creates application definition hulu and assigns it to the app-category streaming.
nx9500-6C8809(config)#application hulu
nx9500-6C8809(config-application-hulu)#
nx9500-6C8809(config-application-hulu)#purview-app-category streaming
nx9500-6C8809(config-application-hulu)#show context
application hulu
The following example shows hulu application definition added to the list of available applications:
hashforcash  hashunited   hoopla hulu
Related Commands
no Resets application category to default (custom)
